Replacement speaker cables for Sony DAVS systems
Discussion in 'Home Cinema Buying & Building' started by timbo74, Oct 19, 2004.
  1. timbo74
    timbo74
    I have a Sony DAVS-800 and am interested in replacing the speaker cable (I know I'll have to solder it on to the existing bespoke connectors unfortunately).
    However I don't have a lot of dosh to spend. If I upgrade to something entry-level like the QED micro cable or Atlas 1.25 cable (about £1.50 a metre) will it actually make much difference to the sound?
    Has anyone had experience of replacing speaker cable on a system like mine, and can they report whether it's worth spending the money?
    Any thoughts appreciated....
  2. timbo74
    timbo74
    Well I thought I'd update anyone who'd read my previous message - I bought some cable from a really good hi-fi shop near me and I'm going to use it to replace all my speaker cable. If it makes much difference to the sound, I'll let you knokw...
  3. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    I would be interested in the results as i've a DAVS888 with the original speaker wire.
    Colin.
  4. timbo74
    timbo74
    OK I'll let you know when I've done it. Should be later this week I hope (new baby notwithstanding!). Tim
  5. coolsurfer
    coolsurfer
    May 2, 2004
    37
    This should be interesting to hear about. Look forward to it :)
  6. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    to fit the speaker wire in u usually haev to push the speaker plug flush to a surface so that the OEM (rubbish) bellwire falls out and then u can put some slightly better stuff in.
  7. mrbenn
    mrbenn
    Jan 16, 2009
    726
    46
    +101
    Reviving this old thread as i was hoping somebody will know if its worth the hassle to re solder speaker cable connections in micro systems?
    does it make any real difference?
