Replacement Screen for Pronto 950
Discussion in 'Home Cinema Control & Remote Controls' started by deanym, Mar 15, 2005.
  1. deanym
    deanym
    May 29, 2004
    1,786
    +141
    Does anyone know where I could get a replacment LCD screen for my prontoNG 950?
    The backlight has given up, which makes it a bit of a :censored: to use in the dark.
  2. John
    John
    Dec 13, 2002
    10,968
    +2,653
    I've been having a look recently myself. Not had much luck, most of the info on RC is about 2 years old . Earth LCD used to do the display , but it looks as if it has been discontinued :thumbsdow . The screen that it does have listed states its not compatable with the pronto , although I think some people have used it with varying degrees of success . I dont want to risk importing one , at approx $80 & the possibility of HMC&E wanting their own slice , for it not to work.
    Have you tried adjusting the light sensor setting , don't know exactly what it does :D but might be worth a try
    Atb
    John
  3. deanym
    deanym
    May 29, 2004
    1,786
    +141
    I've tried everything - its zonked - need a new 'un. :thumbsdow
