replacement remotes
Discussion in 'Home Cinema Control & Remote Controls' started by raigraphixs, Apr 11, 2002.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    63,081
    +23,946
    Where can i get replacement (ractual branded) remotes for tvs, vcr etc, instead of universal ones.
    ta
    rai
  2. laurel
    laurel
    You should probably check with the appropriate manufacturer. Most of them have a spare parts order line.
    Check the web site for the manufacturer or ring the help line.
    You didn't say who the manufacturer was?
    Laurel
  3. Spencem
    Spencem
    Oct 15, 2001
    202
    Northampton
    +9
    CPC have a huge range of origional remotes. Unfortuantly their online catalogue has been down for some time, but their phone number is on the web site and they can either look up what you need or send you a catalogue.
  4. graham.myers
    graham.myers
