Replacement remote for yam dsp750se amp
Discussion in 'Home Cinema Control & Remote Controls' started by GCDB, Feb 8, 2009.
  1. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Hello,
    My amp remote is dying(having to press really hard on volume and tv settings etc). I have split it and cleaned and was better for a while but time to replace i think.
    My question is if i bought one of the OFA 6 in argos £20 could i program that to select the amp to turn to say DVR input and the rest of the keys would respond to the DVR in this example. I definately cant afford a Harmony or something like that though. Failing all this woulod i just be better off buying a replacement of the original for £52 which is really beyond my budget though.
    Thanks for reading and any help would be appreciated.
    Gavin
  2. Dude a llama
    Dude a llama
    Oct 8, 2006
    427
    28
    +61
    Change the batteries it's cheaper!:D
  3. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Mmmm should have expected that and i wish it was that.
    Thanks anyway for the bump.
  4. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    Do not get the replacement remote from Yamaha and I doubt the OFA remote will work the way you wish.
    The cheapest Harmony is available for under £35 and a huge improvement over the Yamaha or OFA remotes. Comet sometimes have Harmonys available at good prices, I managed to get a 688 for £16 from them.
    If you really want to keep to Yamaha I have a DSP757SE with the orginal unused remote if you are interested. The number on the remote is RAV273 WE45840EU.
  5. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Ok thanks for advice, will look for a cheap harmony then unless any other ideas. Failing that i may make you an offer in future for your remote;)
