Replacement remote for Sony Amp Str - DB930
Discussion in 'Home Cinema Control & Remote Controls' started by robyoung, Nov 19, 2003.
  1. robyoung
    robyoung
    Nov 9, 2003
    940
    Milton Keynes
    +65
    Ok the remotes broken, cheapest replacement i can find is about £75 on the net. Would i be better off getting an automated remote for all my toys (VCR, Digibox, Amp, DVD player and plasma telly)
    if so, any recommendations? ease of use/set-up?
    thanks rob
  2. wb1
    wb1
    Sep 5, 2003
    1,671
    38
    London
    +21
    I would highly recommend a Pronto - the control codes for the DB930 (and hundreds of other devices) can be downloaded from RemoteCentral.com so you'll have minimal programming.
  3. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    The Garden of England
    +32
    Agreed... however the only problem I've found with the Pronto is my continuous 'tinkering' of my set up.
    I keep seeing ccf files that I like the look of.... and I blame it all on www.remotecentral.com!!!
  4. robyoung
    robyoung
    Nov 9, 2003
    940
    Milton Keynes
    +65
    Thanks,
    so this pronto sounds great but how much is it gonna set me back?
    got any links to the pronto, info, prices, reviews etc.
    many thanks
    rob
  5. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    +32
  6. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    +32
  7. wb1
    wb1
    Sep 5, 2003
    1,671
    38
    London
    +21
    I think they are £150 inc VAT at Richer Sounds - but you should double check as that might be the 1MB version not the 2MB.
    If you don't want to spend that much I have a Harman Kardon TC1000 that I might want to sell - it's a great remote with all the functionality of the pronto minus the icons.
    Here's a review of it... but mine is in black not see through...
    http://www.remotecentral.com/take/index.html
  8. ancientgeek
    ancientgeek
    I think the 930 remote is bidirectional (the 940 certainly is) it shows a list of radio stations on the remote's LCD that you can scroll through and pick one.
    I don't think Pronto or others will do this, and the 930 remote is a learning remote. I'd try to get the 930 remote myself.
  9. robyoung
    robyoung
    Nov 9, 2003
    940
    Milton Keynes
    +65
    Thanks for all the info. Am looking in to the Pronto, although will now have to be after Xmas!
    But still undecided, you say the 930 has a learning remote? I never knew this as didnt have the instruction manual! :)
    so i could get it to control everything else!?
    cheers rob
  10. ancientgeek
    ancientgeek
    Maybe the 930 remote can control everything else but it's fairly mickey mouse on the macro front and there's no touch screen. I haven't used mine for a couple of years, so I don't remember the details. I did have it controlling the sky box, but the absence of easy to remember key mappings meant I never actually used it for the sky box.
