Replacement Remote for Pioneer DV717
Discussion in 'Home Cinema Control & Remote Controls' started by kismet110, Feb 6, 2005.
  1. kismet110
    kismet110
    Feb 6, 2005
    2,364
    London, UK
    +389
    First time posting on here, hopefully someone can help me with my relatively simple enquiry.
    I have a Pioneer DV717 DVD Player, sadly my daughter decided some time ago it'd be fun to spice up the the pasta by adding the remote control to the boiling pan :oops:
    I made some enquiries for a replacement, best price I found was £95.00. As I had a Sony home cinema system I just switched to using that one, but I now have a need for getting the Pioneer back into action.
    Does anyone know of a) anywhere that sells them for cheaper than above price or b) a universal type remote that definitely works with the Pioneer (bearing in mind the original is totally unusable).
    Thanks in advance.
    ALI
