Quantcast
replacement projector lamps
P
pilchjam
Does anyone know where I can source cheap projector lamps from? I need to replace my lamp on my Sanyo PLC SU-20 LCD projector but cannot find anything anywhere for under £300 which seems pretty damn expensive!! Is there some sort of monopoly on this market or something cos I'm beginning to feel like I do when I go down Tottenham Court Road and try to haggle - no success cos all the shops are joint-owned!! I'm even thinking about looking for a second-hand lamp with a good number of hours left although I have no idea to start looking?:lease:
ntslik
It's the same as the Printer market, often it can cost a lot to replace bulbs (toner etc) but you must consider, at least you can!!!!
