Replacement power cables - Fuse Question!
Discussion in 'Cables & Switches' started by Matt Horne, Jan 3, 2003.
  1. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,109
    83
    Over the Hill & Far Away
    +118
    I am just about to build my own power cables using the Supra Lo-Rad cable..(more as a experiment than anything else) and having checked my amp and dvd player both were originally fitted with 5 Amp fuses.
    Now I have been using some RA cable and I am pretty sure they all come in their sealed plugs with 13Amp fuses.. so is this really a danger to my equipment? . I have to admit I had not thought about this when I bought the cables?
    Matt
    P.S anyone know of good suppliers for high quality Plugs and IEC connectors ?
  2. marck
    marck
    Jul 10, 2002
    600
    London
    I use MK unswitched plugs - these are not expensive but offer a much higher performance than standard plugs.
  3. themadhippy
    themadhippy
    as long as the fuse rating is equal too or lower than the cable rating your ok
