Replacement PC advice
Discussion in 'Desktop & Laptop Computers Forum' started by salthepal, Jun 12, 2009.
  1. salthepal
    salthepal
    Oct 30, 2004
    41
    I've got this 6year old Dell Dimension 8300 which has served me well but it is getting very slow and although I know how to cope with its odd ways like hanging etc., my husband is very impatient and expects it to work instantly. He suggested buying a replacement. I've hear that Vista is a nightmare and have done a quick search and found that I can still buy a Dell with XP OS. I've got no idea though which is a good, reliable machine. We've always had Dells in the past and found them to be overall quite satisfactory.
    Any advice would be appreciated.
    We don't do gaming by the way!
    Thanks.
    Sally
  2. kempez
    kempez
    May 25, 2008
    3,748
    Basingstoke
    +281
    Dell do some decent PC's, as well as companies like Mesh and SCAN.
    Vista's not that bad in my opinion (especially not 64bit with more than 4GB RAM), but a new Windows OS is coming at the end of this year called Windows 7 which is very good. That said, there's not much wrong with XP :)
    I'd get a decent 2.5GHz+ Intel-based PC with at least 2gb RAM, 250gb+ storage and a non-onboard graphics card.
    What is your budget?
  3. zhanxun
    zhanxun
    Jun 3, 2009
    20
    3
    Edinburgh
    how much memory is it using? a quick upgrade of the memory will often do wonders as well as reinstalling the OS.
  4. kempez
    kempez
    May 25, 2008
    3,748
    Basingstoke
    +281
    Could be an option, Crucial have some on their site
    Those and a re-install of the OS would speed things up a bit for the time being.
    A new PC will, however, speed things up a lot, the new architecture's are far superior to netburst (P4), that the 8300 has.
  5. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,727
    Norfolk
    +2,490
    I definitely wouldn't go for an XP if you're likely to keep the PC for another six years.
  6. salthepal
    salthepal
    Oct 30, 2004
    41
    How do I work that out please?
    Thanks for reply
  7. salthepal
    salthepal
    Oct 30, 2004
    41
    Thanks for the detail. Happy to get a decent one as I'm self-employed!
  8. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,727
    Norfolk
    +2,490
    Open up task manager after you've been using the computer for a few hours and check the commit charge (I think, It's not on vista) on the performance tab. If it's a fair bit larger than the amount of memory you've got then an upgrade would benefit you.
  9. salthepal
    salthepal
    Oct 30, 2004
    41
    I have double the amount that I use. Actually I've just done a CC Cleaner registry thing and it seems to be going a bit better at the moment. I'll just have to wait and see what happens.
    Thanks again.
