Replacement needed for Pro-logic decoder
Discussion in 'AV Receivers & Amplifiers' started by David, May 5, 2005.
  1. David
    David
    Nov 26, 2002
    221
    16
    London
    I've got a Mordaunt Short Decoder One pro-logic decoder/amp which drives centre and two rear speakers. It feeds a signal to my wonderful A&R A60 main hi-fi amp and on to a sterio pair of Celef Monitors. I'm very happy with the hi-fi arrangement but the decoder sounds like its on the blink.
    I realise that Home Cinema sound has come a long way since I bought this lot but I want a replacement that integrates in a similar way with my A&R amp and Celef speakers. Does anyone have any suggestions for something suitable?
    Thanks in advance
    David
  2. inzaman
    inzaman
    Dec 16, 2002
    7,959
    Derby
    +1,023
    Moved to integrated's :smoke:
  3. David
    David
    Nov 26, 2002
    221
    16
    London
    Anyone?
  4. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    What sort of budget have you got? The best choises at a guess would be Nad or Arcam.
  5. David
    David
    Nov 26, 2002
    221
    16
    London
    I'm not really even sure what would be a sensible amount to spend. I think we can probably assume a quality budget amp/processor as it wouldn't be used every day. When you say NAD or ARCAM, do you have any specific models in mind? If so what do they do - are they pro-logic replacements, am I going to need more than 5 speakers in total (may be a problem)? Will all the channels be independent (unlike my Mordaunt Short which had a lower-fi rear channel sent equally to both rear speakers).
    Thanks again.
  6. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    No, its just that both Nad and Arcam have settings to set up there av amps with stereo amps and have 12 volt triggers so you can turn the av amp on nad it would wake the stereo amp up at the same time.
    The are full av recievers that are capable of putting out all the :dd: and :dts: modes that are available now. They can also drive up to seven speakers and a sub. You only need 5 speakers and a sub and thats all. The other 2 speakers are optional.
    Yes they will be independant depending upon the decoding method used.
    The budget you would need for this is about £800 - £1000+. Alternatively you could check out Marantz new range the sr /55007500/8500
    Hope this helps :smashin:
