Replacement MA Bronze 2 driver
Discussion in 'Home Cinema Speakers' started by Peter O Sullivan, Jun 20, 2002.
  1. Peter O Sullivan
    Peter O Sullivan
    I am nearly positive I have blown the Mid/bass range driver of my MA Bronze 2. Does any one know if MA would send out a new driver so that I could just replace it myself? Just to save on that service charge I will get in Richer Sounds since I am getting paid s**t money from my summer job.
    Is it also possible for the tweeter on the Paradigm CC-350 centre speaker, it has blown again?
    This does sound bad, me blowing my speakers but all will be ok when I build my tempest sub during the summer. I wouldn't have to crank it up as much to get a bit of a rumble going.
    Any way just to be absolutely sure that the MA is blown?
    I know the tweeter is gone on the Paradigm.
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,451
    Norwich
    +947
    give monitor audio a call, they are a great bunch down there, and they will send you out a driver no problem.
