Replacement IR keyboard/mouse combo
Discussion in 'Computer Peripherals & Consumables' started by Ken, Oct 25, 2005.
  1. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    I have an Airkey wireless keyboard that has finally worn out. My Pronto is programmed with the codes from the Airkey so I need it to use the same coding if possible. Range 10-12'.
    What do you suggest that I replace it with?
    Ken
  2. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    No one?
    Do IR keyboards emit the same code for communication with PC?
    Ken
  3. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    Never mind, I have repaired it.
    Ken
