Replacement Ipod
Discussion in 'Headphones, Earphones & Portable Music' started by skymonkey, Sep 15, 2005.
Tags:
  1. skymonkey
    skymonkey
    May 22, 2002
    25
    England
    Hi, My 4th Gen 20g ipod died after only 5 months(sad ipod icon, i think that means the hard drive?). I have been sent a brand new ipod as replacement. I just wondered how i set it up. Do i need to wipe itunes and ipod updater off my pc and start a fresh or can i just plug it straight into my PC? Also, i have about 3000 songs on my itunes. Is it OK to upload all of those in one go to an ipod? cheers
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,258
    +64
    What you'll need to do is to run the iPod updater first when you plug in the iPod to the PC. It might prompt you, but run the updater anyway. Wait for the iPod to be recognised by the updater. Restore the iPod (have your AC adapter handy) and let the firmware update happen. Then plug it into the PC, wait a while for it to be recognised, and name the iPod when prompted. Don't do anything without naming the iPod first.
  3. skymonkey
    skymonkey
    May 22, 2002
    25
    England
    cheers for the advice. So do i need to run the updater software first and then plug in the new ipod? Is it OK to upload that many songs in one go though?
  4. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    When I had to do (the HDD failed after 3 months) this I plugged the Ipod in first. Itunes then told me that I needed to run the updater. I closed Itunes, ran the updater, started Itunes again and it registered the new unit and then downloaded all my music. No problem.
    Except that the hold switch didn't work. So I got a second replacement and repeated the above. Except that the HDD died after 2 months. So I got my money back and bought the new Creative Zen Sleek.
  5. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,258
    +64
    skymonkey, the only issue is the heat build-up if you're worried about the longevity of the player... this is an issue on practically any HDD-based player when you're heavily using it for long periods. Li-Ion battery performance degrades as they get hotter, and during active, extended use (on AC/USB power) the hard disk can heat up to the extent that battery performance is affected. I've written this to be more serious than it appears to be, but this is the only potential demerit of sticking all your songs on the iPod in one go. If this bothers you, put the iPod back-down onto a heat dissipating surface (large aluminium sheet, etc).
    davehk, Apple's HDD's are the same as most other peoples... Toshiba. It's also no better (or worse) protected than most other DAPs. If your use honestly resulted in multiple HDD failures on the iPod, then it will probably result in multiple HDD failures on any other machine.
  6. shadowritten
    shadowritten
    You think Toshiba HDDs are prone to failure? Try a Creative MuVo2 with a Hitachi drive - abysmal performance!
