replacement HDD for a JVC DR-MH30?
Discussion in 'Blu-ray & DVD Players & Recorders' started by mannyribera, Mar 26, 2005.
  1. mannyribera
    mannyribera
    Does anyone know where I could get a replacement hard disc drive for a JVC DR-MH30? assuming its possible of course. Haven't popped the lid yet so I'm not sure if a specialist hdd is required or a standard hdd could work. any ideas?
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    If it has malfunctioned the easiest way is to open the machine. The disks are usually standard 2.5" computer disks like those in laptops.
    If you are thinking of putting in a larger disk, look around this forum for ideas bu generally speaking it's not possible (or certainly not easy).
  3. mannyribera
    mannyribera
    Ye -its just a replacement needed - no upgrade. Long story - I was at a boot sale and for a laugh I bought a faulty dr-mh30 (minus the internal hdd for next to no money). Had the 'loading' fault which I can fix with a couple of new resistors - but I still need to replace the hdd. As theres not one in there I didn't know what type it could take. Had a quick search just now but cant find 2.5" 160gb hdd's - maybe I'm not looking hard enough. Anyhow I guess I can chuck it on ebay if I cant fix and make more than my money back, but would love to get it running.
