Replacement for SonicStage?
Discussion in 'Headphones, Earphones & Portable Music' started by iansz, Jun 5, 2005.
  1. iansz
    iansz
    Just wondering if anyone knows of any software that can be used instead of SonicStage so I can sync my HD5 with more than 1 PC?
    Any suggestions appreciated.
    cheers.
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    SonicStage is the only software you can use to sync with the HD5.
    However, if both your computers are registered to the same Connect Music Store account, and the HD5 is authorised to that account, then you should be able to sync with I think up to 5 computers.
