Replacement for Philips DVD Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dark Eyes, Apr 23, 2005.
  1. Dark Eyes
    Dark Eyes
    Jun 4, 2004
    124
    I am looking to replace a Philips DVD Recorder that is used to make masters of short films that are then duplicated onto DVDR.
    I was hoping to be able to move a -rw recorder, but there are some things that we like about the Philips / +rw system which I can't find on the -rw recorders:
    you can fairly easily top and tail a recording to remove unwanted material
    it will accept PAL or NTSC without having to change a menu setting
    it outputs NTSC as NTSC, not PAL60
    Can anybody suggest a suitable replacement (HDD is not an option) ?
  2. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    What is the Philips model that you are seeking to replace?
    Why is an HDD model "not an option"?
