Question Replacement for Panasonic TH42PZ700U?
Discussion in 'What Is The Best TV For You?' started by Fxguy1, Jan 8, 2017.
Tags:
  1. Fxguy1
    Fxguy1
    Jan 8, 2017
    2
    Champaign, IL
    Greetings!
    Looking to replace our living room TV with a new TV and so looking for recommendations. Its been 10 years since we've purchased a new TV and so a lot has changed. We currently have a Panasonic TH-42PZ700U 42" Plasma that we will be replacing. Looking for recommendations on type and then features and $500-$1,000 range and then over $1,000 range.
    Thanks ahead of time!
  2. Dodgexander
    Dodgexander
    May 29, 2007
    14,424
    +4,253
    55" ?
    Samsung KS8000 under and LG B6/C6 OLEDs over.
    You get better blacks/contrast/viewing angles with the OLEDs and more comparable motion to your plasma.
    If you want a compromise there's also the LG 9100 OLED which is full HD.
    On a UHD TV SD quality content will look worse.
    Make sure you also view close enough to notice UHD.
    TV Size to Distance Calculator and Science
