Sgiandubh
Established Member
Ok, so I have a Panasonic 50AX802 that i have had since 2014, I don't really have many complaints about it other than those that come with a set of its age such as only having the one HDCP 2.2 socket that is HDMI 2.0 compliant.
Unfortunately, i got up this morning to discover the power LED was flashing and the set will not turn on. I have tried various things and i can eventually get it to turn on, it just sits at the panasonic logo and eventually turns itself off.
I do have a warranty for it and although that will cover any repair that is possible, I am resigned to the fact i will very likely need to start considering a replacement model. However this is where it gets complicated, the warranty is with a retailer (Currys) which means any replacement i need to consider must be sourced from said retailer.
Based on their current stock, I suspect the model they will suggest as the replacement is the Panasonic 50EX700b, however from what i have read about this set, it suffers quite heavily from motion blur, therefore i need to consider another replacement model from Currys at a price point circa £750 or a little bit higher.
I would prefer to stick to 50" but could possible go as big as 55" but no higher, I also have a little bit of wiggle room on price, perhaps as much as an additional £150 which would give a budget of around £900.
Any suggestions/help would be appreciated.
