Replacement for MXE1 in Pioneer's 5th gen lineup
Discussion in 'Plasma TVs Forum' started by Mantorok, Sep 1, 2004.
  1. Mantorok
    Mantorok
    Does anyone know if Pioneer has a 5th generation version of the MXE1 planned for its new lineup?
    The current lineup mentions a "basic" model (FDE). Could this be a replacement? Depends on what it means by "basic" I guess...
    I thought the MXE1 has only been available for a short time though so I'm guessing a replacement model will be quite some time after these new models hit the shelves.
    Anyone know for sure?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,807
    The Borders
    +3,299
    Mantorok
    The MXE1 Plasma Display range has only just been launched - the press release you linked to is for the NEW PlasmaTV range.
    The MXE1 will be current for at least the next 12 months.
    Best regards
    Joe
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    So Pioneer have listened about the YUV and HDMI conections. YUV is now on input 2 on all models I see. So you lose only a composite/s-video input instead of RGB/HDMI. That will affect less people.
  4. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    Joe,
    I am about to purchase a plasma, to be used with a HCPC (in a few months- currently a Pioneer 868 dvd). I am either getting the MXE1, pionner 5th gen, or Panasonic 7th gen. Any thoughts. I am erring towards the MXE1 as I gather it is the most flexible and therefore future ish proof (hi def etc)
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    For HCPC use you could also consider the HD panasonic, whether 6th or 7th gen is of little consequence. The Pioneer 435 is likely to be still limited on the resolutions it can accept via digital input. I have no problem with analogue VGA myself, but as it's on the front panel of the media box, you might feel differently in this case. Cables sticking out of the front are a bit ungraceful, unles it's just your video camera for 5 minutes.
