wolvesphil
Established Member
- Joined
- Dec 3, 2006
- Messages
- 335
- Reaction score
- 25
- Points
- 142
My monitor audio vector vw-8 subwoofer appears to have failed, this a link to the sub VW8
the main specs are:
Any suggestions on suitable replacements, also size wise I don't want it to be too large and if it could be white then it may look better as we have white doors on our BESTA tv units...
the main specs are:
- 8" long throw woofer featuring MMP®II cone technology
- Forward firing driver with downward firing port
- 100Watt (RMS) class A-B amplifier
- Rigid MDF construction
- Non slip rubber feet
- Auto-on-off facility
- Variable volume control
- Variable Crossover/ frequency control from 45 Hz- 150 Hz
- Switch-able phase control 0-180 degrees
- RCA line inputs / LFE channel input.
