Question Replacement for Monitor Audio ASB-2?
Discussion in 'Soundbars, Soundplates & Soundbases' started by McMac, Jul 19, 2018.
  1. McMac
    McMac
    Dec 24, 2007
    180
    28
    Bristol
    +32
    Help/advice please
    I need to replace my 2 year old Monitor Audio ASB-2 Soundbar. It has fallen off of the unit it was sitting on, broken the casing, blowing the fuse when plugged back in and something is rattling inside - so basically dead.
    I am looking for a replacement for it (I need to speak to my insurance company tomorrow). Cost me £649 two years ago. Connected to LG 55b7 via optical but has 3 HDMI inputs + one HDMI out (ARC).
    I have another of these units in my bedroom, so you can tell I like the sound it makes.
    The ASB-2 is a substantial construction and well made (weighs over 11kg).
    I am looking for something as well made, doesn't need a separate sub to sound good. Plenty of space for a larger unit (this one is 18 cm (H): 100.5 cm (W): 16.7 cm (D))
    Tried a Denon Heos 2 years ago for about £500 before I bought this one to replace it. The Denon just did not have the depth of sound or the build quality.
    Thoughts/Advice?
    Thanks in advance McMac
  2. McMac
    McMac
    Dec 24, 2007
    180
    28
    Bristol
    +32
    So, went out to listen to a few sound bars. Most seemed to struggle with clarity when people where just speaking normally. They sounded like I was is in a cinema listening to an advert rather than just hearing a conversation - does that make sense.
    Every shop wanted me to hear the crash bang wallop of a move, rather than jus listening to people talking. 90% of my viewing is watching normal TV programmes.
    Listened to the Sonos at £699 - not impressed but maybe not the ideal testing place in a shop
    Sony at similar prices - too much topend/treble
    orbitalsound 70 at £399 - disappointing
    Lg range up to £1100 - similar to Sony
    Samsung seemed ok. The 750 and 850 where the same price + £100 off. The user reviews on here are commenting on the lack of multichannel DTS.
    I would be feeding speaker via optical from LG 55B7 but would also feed via HDMI arc if better choice If soundbar was capable.
    Struggling to make a choice
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,925
    The Borders
    +3,571
    'Every shop wanted me to hear the crash bang wallop of a move, rather than jus listening to people talking. 90% of my viewing is watching normal TV programmes' - happens at Trade Shows too, drives me nuts.
    'I have another of these units in my bedroom, so you can tell I like the sound it makes' - another MA unit would seem to be the obvious contender, if you like their 'sound' and they have something in your price range.
    Joe
  4. McMac
    McMac
    Dec 24, 2007
    180
    28
    Bristol
    +32
    Hi Joe
    Hope you are well.
    Had a listen to the ASB10 (active soundbar). It was OK but not as good as the ASB-2. Off tomorrow, so will go and have a listen in a few shops.
    I may bring the unit in my bedroom down and buy something for up there as a replacement.
