Question Replacement for kef 2005.2 subwoofer psw 2010
Discussion in 'Subwoofers' started by cdwmc4, Jun 9, 2015.
  1. cdwmc4
    cdwmc4
    Mar 23, 2012
    65
    Hi i am looking at replacing the above subwoofer. I would appreciate any advice as i am new to this. Thanks in advance
  2. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
  3. logic_187
    logic_187
    Aug 9, 2005
    829
    28
    +53
    Depends how much you want your spend really
  4. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,393
    +1,303
    Has the sub gone pop? If so and you don't want to upgrade wasn't there somebody repairing them
  5. cdwmc4
    cdwmc4
    Mar 23, 2012
    65
    Yes sub is rumbling
  6. cdwmc4
    cdwmc4
    Mar 23, 2012
    65
    Thinking of bk but as direct sales not comfortable as would prefer a shop
  7. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    Just pay with credit card.
    If you buy a mainstream brand you will pay 50% more for similar subwoofer.
  8. cdwmc4
    cdwmc4
    Mar 23, 2012
    65
    Yes thats what it seems like. Looking at getting the bk 400
  9. cdwmc4
    cdwmc4
    Mar 23, 2012
    65
    From reviews on this forum people really rate the sub
  10. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    that is ideal for small-medium rooms for home theatre and music.
    For larger rooms for movies I'd go for the Monolith.
    If you're looking at 12" sealed box there's the SVS SB2000. The BK has a higher grade finish, but I believe the SVS is superior for movies.
  11. cdwmc4
    cdwmc4
    Mar 23, 2012
    65
    I am thinking of buying the bk xxls400 Has anyone purchased the sound care super spikes advertised on BK website and would they be required. I am thinking of purchasing FF
  12. DaneP
    DaneP
    May 13, 2015
    19
    London
    +3
    I've got an xxls400 but didn't see the need to pay more for the super spikes. It comes with regular spikes and a levelling nut that screw into the main feet so I don't really know what they'd add...
  13. cdwmc4
    cdwmc4
    Mar 23, 2012
    65
