Flazsa
Morning. I have had a Samsung 65KS9000 since May 2017, since then it has already had two replacement screens through various faults. It has now developed a third fault where there are clumps of dead pixels at the top of the screen.
I have been back to Fenwicks in Newcastle where I purchased and they have said that the will replace the TV seeing as the screens are no longer made. I have been told that the nearest available set is a Samsung 65NU8000, which i can have or credit to the value of 1260 pound to put towards another TV.
Question is do you think that the NU8000 will be a similar spec TV or is it worth asking for them to match against something higher? Any help would be appreciated
Paul
Paul
