Replacement DVD Hard Drives.
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jamesy2004, Apr 22, 2005.
  1. Jamesy2004
    Jamesy2004
    Does anyone know if you can replace DVD recorder hard drives with replaced formatted ones? I have the JVC DVD/HDD Recorder: DR-MH20. Which has an 80gig hard drive. For example if i was to replace the hard drive with a 160/200gig one.??
  2. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    I dont think this is an option as I am sure the unit is limited to the amount of recording via its BIOS/SOFTWARE.
    unless someone can advise any different?
