Replacement driver Rel Qbass subwoofer
ONKYOYoYo
All
I was wondering if someone can tell me what would be a good / better replacement driver for a
Rel Qbass subwoofer (Not sure of the model, just has Qbass on the front)
Please can someone tell me what would be appropriate dimensions for one and the specs
such as ohms, wattage. I do not want to modify the hole of the subwoofer case
I have been reading on google but could but could not find an answer so thought i would post here
Thanks all in advance
Mr Wolf
A few years ago I bought a replacement 12” driver for an old REL Q100 from BK Electronics, they knew the exact spec of driver required as they made loads of subs for REL back in the day. If you don’t get anywhere I would shoot them an email.
ONKYOYoYo
Thanks for the reply mate
I have sent them an email
ONKYOYoYo
I wanted to ask
When finding a replacement driver is it ok to increase the power of a driver,
for e.g. if the original was rated at max power 180 W, can a 200 W be replaced and sound the same or better
Thanks all
Mr Wolf
I wanted to ask
Thanks all
No problem at all. I wouldn’t want one though that has a lower impedance or sensitivity rating.
Mr Wolf
I am keeping the ohms the same but can the power be increased
Yes because it’s just a rating of what it can handle. You can’t have too much power handling capability unless it reduces the driver’s sensitivity which is something you don’t want as it will reduce the output level.
ONKYOYoYo
Just doing some research and found this one,
I took some rough specs from different specs i found from the web. I am waiting for a reply from BK which will give me the correct specs
So I should keep ohms and size the same but can increases in power ?
Mr Wolf
Yes but it’s not as simple as that. A driver has many other parameters that need to be considered.
The driver I bought from BK for £40 is also suitable for the Q-bass. Unfortunately it’s no longer available but BK should definitely be able to give you the specs.
The replacement driver made the sub sound much better than when it was new.
ONKYOYoYo
ok thanks
ONKYOYoYo
Hi all
To all the subwoofer experts and people who have replaced the drivers in REL Qbass subwoofers
Would this be a good replacement that will sound the same as the original or better
I am still waiting for BK to reply to me but thought I would post this
Thanks all
Gasp3621
Don`t bother emailing to BK, you rarely get answer!
Call to them NOW! Here is the number: 01702 527572
Ask to speak with Tom Pearce (tech manager) and you will get the answer you are looking for.
Mr Wolf
And while you're speaking to him, tell him to ask his boss to start making a 1000W ported 15" subs with Class D amps.
ONKYOYoYo
Cant get through
Tried, phone rings but no one picks up
Do you think the soundlab driver i linked is a good replacement
I have seem some people have replaced with a peerless driver
Gasp3621
Cant get through
No idea about the driver. Keep calling, they will answer at some point. Perhaps having lunch etc.
ONKYOYoYo
Does the edge / surround matter when replacing the subwoofer driver
For e.g th peerless and the VISATON have rubber or foam edges but the soundlab one doesnt
Does it make a difference in a subwoofer
ONKYOYoYo
The frequency response from the MCM ones is
Frequency Response Max: 4 kHz
Frequency Response Min: 50Hz
The ones from the VISATON W 300
FREQUENCY RANGE
32 - 2500 Hz
The soundlab
Frequency Response (Hz) 30-4200
The MCM speaker has a rubber or foam surround also
The frequency response range covers the VISATON
IS this ok
Please can the subwoofer experts reply
Thanks so much in advance
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
Latest News
Samsung QD-OLED TVs primed for 2022 launch?
  • By Andy Bassett
  • Published
Sky to add NBCUniversal's Peacock service
  • By Andy Bassett
  • Published
Bang & Olufsen announces Beoplay EQ TWS earphones
  • By Andy Bassett
  • Published
AVForums Podcast: 28th July 2021
  • By Phil Hinton
  • Published
Sky drops Sky One brand and introduces Showcase and Max
  • By Andy Bassett
  • Published
