Replacement drive units for TDL Speakers?
Discussion in 'Home Cinema Speakers' started by nathan_silly, Jan 26, 2003.
  1. nathan_silly
    nathan_silly
    My mate has got a pair of TDL Electronics floorstanders and the woofer is damaged.
    Where can I find any info regarding replacement drivers, and info to find out what model it is?
    There is no sticker with a model number. I'll be getting the driver serial no soon.
    Nathan
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I think that TDL went bust
  3. nathan_silly
    nathan_silly
    Yeah I thought so too- but he just he needs to replace the woofer.
    Anyone got any links for the TDL product range, so I can track down the model?
    FYI, it's a 2 way floorstander, the tweeter unit is square (not the tweeter itself, the actual whole tweeter unit)
    And the woofer is round with about 6 screw holes. There are two square ports on the front bottom.
    Nathan
  4. bones`
    bones`
    Oct 12, 2002
    1,961
    Preston
    +47
    I think most TDL floorstaanders had the square ports as part of the transmission line design. I used to have some RTL 3's that fit that description and cost about £400 if thats any help. I'm sure Wilmslow Audio do replacement drivers for TDL's if you can identify the model.
  5. nathan_silly
    nathan_silly
    Thanks for the info :)
