Replacement covers for Mission 77DS ?
Discussion in 'Home Cinema Speakers' started by Chucky, Aug 11, 2002.
  1. Chucky
    Chucky
    I just managed to buy a pair of Mission 77DS in black, however, it turned out that the fabric covers are quite damaged and have spots on them (and when i looked at them before, they seemed fine).
    Apart fro Mission themselves, is there a place where i can buy replacement covers, especially in white?
  2. KevB_UK
    KevB_UK
    I've not tried it but it looks like the back plate will unscrew allowing you get the covers off, if it's as easy as this then you can replace it with some new fabric fairly easily. I know car audio shops sell suitable material, maybe hifi shops do to?
  3. Chucky
    Chucky
    I think it only looks easy, but after trying to unscrew the back plate (boy, they use the TOUGHEST screws i have come across, requiring super heavy duty titanium screwdrivers),
    it seems that fabric is somehow glued onto the grill.. I dont even know exactly how to take it off!
    You suggestion is definitely taken onboard! I will try to speak to Mission tomorrow to find out how to take the rabric off, for a start.
  4. jonna
    jonna
    Mar 25, 2002
    3,187
    Cheshire
    +2,459
    Is your name chucky or scooby doo- 'rabric' . Hee Hee Hee Heeeeeee!!!
    jonna
