Justhe1
I have just had my new plasma mounted on the wall, above the fireplace (only place it could go) and I have had to have it mounted about 10cm above the mantel for comfortable viewing.
As a result I can no longer use my relatively new mxc tannoy centre speaker, which I'm gutted about, or even my smaller Mission M71i speaker that I currently use as centre rear.
All my other speakers are Mission M72's (front), Mission M70's (rear) and Kef PSW1000 sub. (all are beech/maple finish)
Can anyone please give me some advise on a small profile centre speaker that will match my existing units sound wise (The narrower and lower the better), the only other option is to sink a speaker into the new fire surround, but that may look a bit naff...
Stupid question, but does the centre speaker really need to be in the centre - ie if I sighted it adjascent to the fireplace would the panning be notably wrong??
I listen to music and watch DVD's - and no cannot afford to replace all my speakers!
Any help greatly appreciated.
J
J
