Replacement car keys
Discussion in 'Motoring' started by DrPhil, Feb 24, 2014.
  1. DrPhil
    DrPhil
    Jul 19, 2006
    24,512
    Ireland
    +10,504
    I have an 05 Peugeot 206. Only got one key with it when I bought it. Been quoted about £90 for a new one!
    Are there any cheaper alternatives? Been looking on eBay and there seem to be some, but are they cheap crap or worth it?
  2. un1eash
    un1eash
    Nov 14, 2007
    5,022
    2
    +1,442
    Sounds about right, years ago a friend got a replacement for his 206 Gti and paid similar money.
  3. car-man
    car-man
    Mar 18, 2008
    2,194
    116
    +1,448
    If the £90 includes coding to the car then it isn't too expensive.
    With the Peugeot you need to code the keys using a 4 digit code that you should have with the car on a card, If you don't have the code you will have to buy it from the dealer at around £30.
    Even keys you buy on ebay will need coding to the car...I have the software to do that.
