MarkP80
Established Member
Hi guys,
I'm after a recommendation for a couple of replacement cameras for my Aspect NVR CCTV system. A couple of the existing cameras had condensation inside the lens, and when I opened them up they had actually leaked water in and were damaged - so I plan to replace them.
The cameras are poe, fixed position, non-zoom, 4MP turret cameras. (Photo attached to show type)
The label says model - L-TU-IP4M-3.6-1 and 3.6mm lens.
I was happy with the spec of the cameras until a couple stopped working. Looking at the Videcon website, I believe this model is obsolete.
Does a replacement need to be specifically an Aspect camera, or would any poe camera work? (there's only an ethernet cable plugged in) Will I need to do anything in the Aspect software to specify any new camera?
And should I be looking at something with more resolution than 4MP now?
Any advice greatly appreciated.
Cheers,
MarkP
Cheers,
MarkP
