Replacement cable
Discussion in 'Cable TV & Virgin Media TV' started by Earlstreetblue, Sep 15, 2007.
  1. Earlstreetblue
    Earlstreetblue
    Dec 17, 2004
    137
    N E Lincs/Whitby
    +4
    I have been having the odd problem recently with the cable that NTL plumbed in nearly 8 years ago and is looking a bit worse for wear. Can I replace it with something better? if so what and where could I get some?
    The cable I have at the mo runs from a split where the other goes to my cable modem (SB4100 surfboard) and is approx 20' in length. I don't actually need that amount as I've now moved the TV nearer to where it comes in from outside, so I would only need approx 5-6'.
    TIA
  2. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
  3. pekay
    pekay
    Nov 14, 2004
    65
    11
    +3
    Cant believe you've still got the old SB4100, fill the form in online and upgrade.
  4. Earlstreetblue
    Earlstreetblue
    Dec 17, 2004
    137
    N E Lincs/Whitby
    +4
    I probably would, if there was something wrong with it, but has worked flawlessly :D
    What advantages would I get then, if I did?
    Thanks for the link, but that's too long (10mts) I'm afraid. Would any coax cable do, or do I need a specific type.
  5. serial killer
    serial killer
    Aug 9, 2006
    131
    +16
  6. OneTrouble
    OneTrouble
    Aug 20, 2007
    640
    28
    +28
    just be a 100m roll for 25squid..b&q..cut the length you need..get the f connectors from locals or maplins...save the rest of the roll for the future
  7. Earlstreetblue
    Earlstreetblue
    Dec 17, 2004
    137
    N E Lincs/Whitby
    +4
    I've been given a 1.5m RG-59/U 75 ohm cable, will that do?
