Replacement bits
Discussion in 'Home Cinema Speakers' started by bobsdad, Jun 27, 2005.
  1. bobsdad
    bobsdad
    Can anyone help out with any info on where to get hold of a replacement woofer for JBL Control One series.
    There's a very annoying rattle/buzz/popping when the bass gets a little meaty.
    There's no response from Harmon in the UK.
    Spec is...
    Frequency Range: 70 Hz - 20 kHz (-10dB).
    Power Capacity: 150 Watts (test signal of IEC filtered random noise with a peak-to-average ratio of 6dB, 2 hrs duration).
    Sensitivity: 87dB 1W, 1m.
    Nominal Impedance: 4 Ohms.
    Crossover Frequency: 6 kHz.
    Components: 135mm (5 1/4 in) low frequency loudspeaker 19mm (3/4 in) polycarbonate dome tweeter.
    Any help on where to get something like this would be more than appreciated.
    Many Thanks in advance.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  3. bobsdad
    bobsdad
    Extra info from owners manual which differs from above...
    Frequency Response 50Hz – 20kHz
    Power Handling (Peak/Continuous) 200W/50W
    Sensitivity 89dB/2.83V/1m
    Nominal Impedance 8 Ohms
    ...if it helps
