Replaced my sound card
Discussion in 'Computer Components' started by Ken, Jan 13, 2002.
  1. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    Today I replaced my SB 5.1 with a M-Audio 24/96.
    What an improvement, more fidelity, deeper bass, crisper high's and over all better definition. Speach is also much clearer and intelligable. It is a bit on the expensive side, but when put into context with my sound system, it is insignificant and an obvious purchase. Highly recommended.
    Denon A10SE
    2x Linn LK240 driving a pair of AV5140 mains
    Linn AV5120 Centre
    LinnAV5110 surrounds
    IPL sub
    Ken
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,550
    UK.
    +3,056
  3. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
  4. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    A note on CD play.
    Though, without doubt the M-Audio 24/96 is the best card for DVD, the DAC output doesn't hold a candle against my stand alone CD player (Linn Karic). So it is still not a complete audio solution.
    Having said that, it is definately worth having for DVD play alone.
    Another thing, I was having some lip sync problems with the TT player with my SB 5.1, but now, with the M-Audio it seems to have gone away.
    Ken
  5. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Yes, agreed.
    I have noticed definite sound improvement from my Hurcules Fortissimo II.
    However, the biggest factor in my decision to change was the fact that it seems much more compatable.
    I was suffering from stuttery DTS and very obvious framerate problems in both Powerdvd and TheaterTek.
    The M-audio cleared these up immediately!
    Recommended (but pricey)
  6. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    With regard to cd play: Yes you are indeed correct it doesn't sound as good as my cd player (naim cd5) but then I didn't really expect it to. The naim (and presumably your linn) are highly specialised pieces of equipment, even in their field. Even in fairly high-end audio equipment there are huge differences in the WAY they play cds. The Naim for instance focuses on rhythm and timing and pays very little attention to imaging and soundstage.
    I, for instance couldn't live with the top of the range Marantz cd player any more than I could the AP 24/96.
    You pays your money, you takes your choice.
    What the AP24/96 does though is offer me the chance to play mp3 and 24/96 recordings and not be disgusted by the sound (like the fortissimo).
    Also I'm sure there are many people who use their budget dvd players to play music cds and I wouldn't be surprised if this card can put up a pretty good fight with those.
  7. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    Agreed Alex,
    I didn't really expect it to be as good as my CD player, but from what I'd read on the AVS forum I expected a little more, but then it is all relative anyway.
    Not to say that this card sounds bad by the way the M-Audio is probably better than a lot of budget players.
    I have to say that my home cinema experience has definately improved by a large margin in the last month.
    Ken
  8. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    I just got one on Saturday, absolutely amazing sound compared to the Soundblaster Live !!!!
    Bought it secondhand, a Bargain :)
    I Just need to buy TheaterTek as well now.
    Mark G.
  9. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Yes, TheaterTek is good - The automatic (and customisable) aspect ratio stuff is great. I also like the lack of intro graphics.
    The only thing I don't like are the on-screen graphics. I just don't think they look good on a large projection screen. I actually like the Powerdvd onscreen info (play, pause, etc) as it's just text and you can choose your own font and colour.
    With regard to your ap24/96 - if it's been around a while then make sure your drivers are up to date. Well done for finding a second hand one though!
    Good luck!
    Alex
