To replace the HDD in a DMR-BWT720 without losing the recordings.
I posted last year that I thought that it must be possible to save the recordings when changing the HDD and that it probably required the serial numbers of the HDDs to match. Well it is both the serial number and the model number that have to match, possibly the size of the disk too; I have only been looking into replacing the HDD with one of identical capacity so cannot confirm the latter.
Well the HDD change can be done!
I have replaced the HDD in one of my 720s and kept all the recordings. I think the same procedure would probably work with other Panasonic HDD recorders.
What is required:
None of the above steps will make any changes to your old HDD and it can still be put back in the Panny. If the Panny still asks for a format then something has gone wrong but as long as you don’t format you can still put your old HDD back and the recordings will still be there.
Note the replacement drive must be a Western Digital one with a Marvel controller. Each HDD manufacturer uses their own specific VSC (vendor specific codes) to write to the SA (systems area) of the HDD. The SA is hidden from normal use and employs techniques such as negative cylinder numbers for access. The passport is stored in the SA and in part in the on-board ROM.
Warning – WDMarvel is very powerful and it is easy to make an unintended change that turns your new HDD into a brick.
Good luck
What is required:
- A PC running Widows (XP or later) and the ability to attach a SATA drive directly to the motherboard. It will not work if you try and use a USB to SATA adaptor.
- A bootable CD or USB with a flavour of Linux on it. I used Ubuntu - Download Ubuntu Desktop | Download | Ubuntu
- A copy of Victoria - HDDGURU: Victoria (free)
- A licensed copy of WDMarvel v3 – WD Marvel Repair Tool – Utility to recover HDD WD Marvel (A free demo version is available and whilst good for testing your hardware setup it will not write to a HDD and so can not be used. Cost is currently 15USD for one month’s use.
- A WD 1Tb HDD using a Marvel controller. I fitted a WD 10EURX, about the cheapest 1Tb drive around. It has to be a WD Marvel drive as you will be using Vendor Specific Codes to change parts of the HDD’s passport.
Two parts to the procedure:
Clone the HDD
Change the HDD’s passport.
Clone the HDD
For this I booted into Ubuntu and then used the DD command to clone the drive. If your drive is failing you might want to use DDrescue – details here:
Ddrescue - GNU Project - Free Software Foundation (FSF)
I attached both old and new drives at the same time using a USB3-SATA adaptor (adaptor OK for this step) for one drive and straight SATA for the other. This took 7 hours to clone. DDrescue will take much longer. It’s useful if using DD to make provision to monitor progress such as PV or “status=progress”.
Change the new HDD passport to partially match the old HDD
Boot into Windows and run Victoria. Connect each of the HDDs one at a time (USB caddy OK for this) and select from the available HDDs and then press “Passport”. From there make a careful note of both the Model number and Serial number of both the old and new HDDs.
- Connect the new HDD to a SATA port and reboot the PC.
- Run WDMarvel and enter the licence number you have been emailed after paying the 15USD. (you need an internet connection for the number to be verified and the writing function to be enabled.
- Select the new HDD from the list on the left and then press “Detect”. The “Drive” box on the right will populate with passport details of the HDD you have selected. As likely you will not know which HDD to select from the list just go through each of them, note many non-WD drives will not report their passport.
- Select the “Heads” tab and then “Change serial” and enter the old drives serial number.
- Repeat the last step but for “Change Model number”
- Select the “edit config” entry and then untick the entry for “use Model from flash”
- Click on “Save to SA”
- Reboot and check with Victoria again that the model number and serial of the new drive match those of the old drive.
Good luck
