replace ps2 with xbox
Discussion in 'Video Streaming Boxes & Services' started by obiwan, May 22, 2004.
  1. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
    bought car, has ps2 in boot hooked up to a panny cq-va707n, cq-dvr909n setup.
    i want to take ps2 out and install xbox in its place, but not sure about the cables.
    the av out cable from ps2 disappears under moulding in car, does this have to be long enough to reach head unit, ie. jury rig an old cable?? or if i started to expose cable am i likely to find a standard length cable and rca plugs etc???
    thx
  2. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
  3. Dreadnort
    Dreadnort
    they should be the standard lenght with RCA at the end or i may be joined in the middle.
    Point to note is that the xbox will suck the life out of the battery very quickley
