Replace LG DA5620
Discussion in 'Home Cinema Buying & Building' started by cdrider, Sep 22, 2005.
  1. cdrider
    cdrider
    Oct 1, 2003
    722
    +40
    Morning,
    I've got the above all-in-one system and the DVD player stopped working
    a couple of weeks ago. After an hour or so the payer starts to skip
    then locks up. The vents at the top get very hot just on the right hand
    side. LG aren't interested because it's out of warranty and the repair
    centre they recommended have said it'll be another two weeks (making a
    total of a month!) before they can look at it.
    I'm going to pick it up tomorrow but is it worth getting it repaired?
    If it works out cheaper to buy a new player can I get one that'll fit
    the old speakers? All the speakers and sub plug into the back of the
    player. Had a look around the net but I can't find any pictures of the
    back of it. Might make more sense if I can get a photo...?
