Answered Replace HDMI 1.4 with 2.0 for 4K?
Ste7en
I'm about to swap out my 103D with a 203. Pretty sure the HDMI I've got in place at the moment is 1.4. I'm going to have to replace it with a Premium HDMI for 4K aren't I?
Cable is 3 metre length.
Joe Fernand
AVForums Sponsor
Forget about HDMI Version numbers - they are not applicable to cables.
If once you install the New Player you find your current cable has problems with the UHD signal then yes replace it with a Premium High Speed Certified cable.
Joe
PS At 3m it is more than likely that your current cable will be fine for UHD.
