Replace AV32r with unidisk sc
Discussion in 'TAG McLaren Audio Owners' Forum' started by illy, Jul 18, 2004.
  1. illy
    illy
    I'm thinking of upgrading my DVD player a Rotel 1080 with a universal player. Which then moved on to another issue as I have not got the 5.1 bypass on my 32r SP. So I thought I might replace the 32r with the Unidisk SC, has anyone any views on this? My amp is the Tag 100 x 5.
    Rotel 1080, Tag AV32r 100 x 5, JMLab Mezzo Utopia fronts with center, Lumagen HDPro, Seleco 800HD
  2. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    If you do not have intention to go for DP I'd do it, but it is my pesonal opinion.
    If X3ELS manages to SDI Unidisk than for sure.
