Repairing plastic camera bodywork
Discussion in 'Photography Forums' started by steev, Nov 15, 2004.
  1. steev
    steev
    Oct 22, 2001
    236
    19
    Beds, UK
    The battery cover on our Kodak has broken. It's right at the hinge. I've tried Superglue, but it doesn't hold. Is there a better sort of glue for these plastics?
    It's out of warranty and I just know that a professional repair will cost more than the camera is worth. It's a 2MP model (CX4230) and a couple of years old. I know a newer model would not cost much, but money is tight and it's good enough for our needs.
    Steve
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    silicone might work, but because it will take a lot of use it might never really work right. Is it just the door? You might be surprised if you ring the spares department
  3. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Oh bugger, we've seen this situation before haven't we Sean :rolleyes:
    I'm afraid Steve you are basically stuffed. The plastic used on most cameras does not glue well even with high grade superglue. There is not normally enough room to use epoxy resin either and I doubt it would hold anyway. My advice is to just tape the battery door shut and live with a slightly scruffy camera. These things do not come apart easily either as I discovered.
    In case you wondered how I am an expert on this situation. I dropped my brand new KonicaMinolta digital camera after less than a week. It broke the battery door clips and hinge. Superglue appeared to work until the battery’s were fitted at which point the glue failed miserably. The camera worked fine with the door gaffa taped shut but looked nasty. I got a quote of £180 to repair a brand-new £300 camera :eek: I managed to get it reduced but it still hurt.
    Cheers, Mylo :)
  4. Garrett
    Garrett
    Apr 21, 2001
    39,878
    2
    167
    The best thief you’ll never see.
    +6,538
  5. steev
    steev
    Oct 22, 2001
    236
    19
    Beds, UK
    I managed to unscrew the bottom panel to remove the rest of the hinge. It's a puny piece of plastic with very little surface to glue. The Superglue just doesn't seem to make a firm bond and it's under a fair bit of stress from the batteries pushing against it. I'm sure tape would do the job, but it's an annoyance.
    Actually, I just had the thought of using some self-adhesive Velcro. That would make it easier to replace the batteries and that stuff sticks pretty well.
    I have mailed Kodak to see if I can get a replacement. We shall see what they say.
    Steve
  6. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Thats a good start :thumbsup: Do you think you can fit a new door/hinge in one piece? The cost of a battery door is only about £10 .
  7. Flimber
    Flimber
    Sep 22, 2002
    13,672
    Yorkshire
    +4,476
    Find a dud one on eBay and make like a cannibal.
  8. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    one of my friends busted my old camera, it would have been simple to fix had it not been designed by morons, after giving me 3 300volt electric shocks and me spasming and dropping it on the floor, it was finally "dead"
  9. bowenjones
    bowenjones
    Oct 24, 2002
    2,798
    Wales
    +436
  10. steev
    steev
    Oct 22, 2001
    236
    19
    Beds, UK
    I bid on that auction, but got sniped at the last moment. I mailed the guy direct and he has more covers. There's one on there now that I could have for $9.99+delivery.
    For now I've fixed it with some sticky-backed velcro. Wonderfull stuff. I may consider a more permanent repair later. With the price of cameras now I may be better off upgrading anyway. Not an issue until after the Xmas spending festival.
