Wildpredator
Established Member
After some advice please or at least bounce some thoughts out off my head.
To give background my current setup for last 9+ years:
Yamaha RX-V3067 - 7.2 channel:
Rated Output Power (20Hz-20kHz, 2ch driven) - 140W (8ohms, 0.06% THD)
Dynamic Power per Channel (8/6/4/2 ohms) - 175/220/295/415W
5 x Kef Q Series Speakers: Q700 Towers x 2, Q600c, Q300 bookshelf
I didn't have the room for side surrounds (still don't) so I opted to bi-amp the front towers with last 2 x powered channels.
Fast forward 9 years and my 3067 is starting to play up. It will work when the room is hot, or after multiple turn on/off attempts. Having a read it does sound like I have the same issue as being talked about on these threads:
www.avforums.com
www.avforums.com
The issue looks to be a bad join between the digital sound processor chip and board. I do have a friend who may be able to attempt the repair but I have reservations as does he.
I checked and found a Yamaha approved repair centre by me. I called and explained the issue and they advised they would not re solder the joint due to potential issues down the line, they would rather opt for replacing the board completely.
I think the cost of the board was roughly £245 plus £80 labour to fit - it is also not too far to travel so I won't need to post the unit.
They did say it might not be economical to repair as it might be cheaper to buy a new AVR.
I know it was a long time ago, but I am sure the AVR cost close to £3K!
Admittedly I have had some issues enjoying 4K (AVR is only HDMI 1.4) but I've worked round them now. My 4K bluray player has 2 x HDMI out, one audio and one video - so I can send one to display and one to the AVR to enjoy HD sound formats whilst watching Movies.
For the games console, Series X, there is no optical out, or 2nd HDMI, so I've had to connect to the TV via HDMI and use the optical back to the AVR to use the amp/speakers with gaming - this is fine for me at the moment.
Where my question goes; is it worth spending the money to fix the AVR? To me it feels like it is.
I did start to look at more recent Yamaha amps, keeping in mind I don't need more than 7 x powered channels in my current situation and whenever I have the space to do so I think I'd move to processor/amp separates.
As an example I was looking at the Yamaha RX-V6A - can pick it up for exactly double the repair price at £650
But is a 9+ year old £3K amp going to be comparable to a today's amp from the same brand at £650?
The output per channel is less:
RX-V6A
Rated Output Power (20Hz-20kHz, 2ch driven) - 100 W (8 ohms, 0.06% THD)
RX-V3067
I have a basic understanding that for every 3db louder, you need to double the wattage - so would this be negligible?
Essentially I did my research and have been happy with my setup for many years and I am wondering if it is worth repairing the AVR I currently have or time to buy new? Has there been improvements I'm missing, would a drop in wattage be noticeable? Was the 3067 over quoted and real world I was probably never really having 145 watts delivered per channel?
I don't want to buy a new AVR and be disappointed it doesn't live up to my old one
I've been out of the game and lack up to date knowledge and reaching out for any comments or advice from those who know more than me on this subject.
Any advice and help greatly appreciated, thank you!
Question - Yamaha RXV3067 no sound
My RXV3067 just packed in, for a few weeks the sound was not coming on after the second relay clicked. I would turn it off and on again and usually it worked. Eventually that stopped helping so I did a full Initialization and then it worked again for a day or so then stopped. I then went through...
Problem with Yamaha receiver
Have a Yamaha RX-V3067 that started behaving very strange for a week. The sound disappears completely but the video remains (uses the receiver for only two speakers NO 5.1 / 7.1 mm), sometimes it may help to restart it a few times and change the source. Sometimes I have to do a factory reset...
RX-V6A
RX-V3067
