Reomte control fire.
Discussion in 'Home Cinema Control & Remote Controls' started by lonny, Mar 6, 2003.
  1. lonny
    lonny
    Jan 7, 2002
    St Albans
    +5
    Hello,
    I am currently considering buying a magiglo fire that is available with remote control :
    http://www.magiglo.co.uk/Products/Standard/EliteThermobox.htm
    Has anyone any experience of programming a pronto to do this job?? I think that the remote may use RF rather than IR. Does anyone know what remote would be suitable if this was the case??
    thanks,
    Lonny.
  2. mike.hutch
    mike.hutch
    Feb 28, 2001
    1,005
    48
    Bristol
    +27
    When I read the subject of this thread, I thought you were going to say your remote control had caught fire!
    Can't help with a way around your IR to RF problem without spending loads of money on a ProntoPro, which does RF I believe, ther may be some sort of X-10 solution, try www.letsautomate.com
  3. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    There is a specific X-10 device for converting IR from your remote to RF. The problem will be that you won't have the IR equivelent of the RF code neccesary to operate the fire.
    I too considered this fire (the Duo, I think its called), because I wanted to have everything operated remotely on my universal, like you. I decided against it in the end, as I couldn't see a way round learning the command onto my remote AND I was put off the remote version Duo by several stockists, who claimed there were reliability issues with these type of fires.
    Anyway, I think the fire is one of the best in its class. The flame pattern is much more realistic, as is the coals, then the mainstream manufacturers.
    A tip for you:
    I wanted to control some X-10 plug in modules for lamps, etc using my conventional learning remote. Rather than buy the 'proper' X-10 device for this purpose (£60) - I found that the powermid transmitter (£15) could do the same job.
    Bought the powermid from letsautomate. Got a pack containing appliance module, lamp module and X-10 remote for £50 from B&Q. Learnt the commands from the supplied X-10 remote (it sends out IR + RF at the same time) onto my main remote - worked a treat.
  4. lonny
    lonny
    Jan 7, 2002
    St Albans
    +5
    thanx for the suggestions guys - more kit for me to buy I see....
  5. patwestlake
    patwestlake
    Jan 27, 2003
    129
    Cardiff
    +6
    The pronto pro does Ir and RF.......
    Any use?
    Pat
