I
ianroscoe
Help!! just done cylinder head gasket all ok there having prob with timing belt.
I have put the peg into the flywheel for tdc for No1 cylinder the timing mark on crankshaft is ok(lined up)also the diesel pump is lined up.
the belt marks all line up spot on.
the tension ajuster is not ajusting up as the belt is slack on that side even if i push the ajuster as far as it wil go.
i am sure the belt is the right one as its the same belt formost of the renault range and citron and some vauxalls
anyone any clues
regards Ian
anyone any clues
regards Ian
