Renault Clio Radio stays at CODE will not go to 0000
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by realitybites, Mar 19, 2005.
  1. realitybites
    realitybites
    Jun 3, 2003
    613
    Hi, I am hoping someone can help. I have a 1.4 Alize 1999 with a Phillips code protected radio. I have recently disconnected the battery so the unit came up CODE and then 0000. It accepted the code fine. Have again disconnected battery again had same sequence but inputted wrong code and the player refuses to go to the 0000 mode and just stays in CODE mode. Have disconnected battery again but no joy. Any help greatly appreciated.
  2. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    There may be a time delay which will have to pass before allowing another code input. Do you have the correct code ?
  3. chalkdust
    chalkdust
    Jul 8, 2003
    798
    +24
    Yes, there is a time delay which doubles after every wrong entry, 1 min, 2 min, 4 min, 8 min and so forth. Only tried a couple of times so is a bit puzzling.
  4. chalkdust
    chalkdust
    Jul 8, 2003
    798
    +24
    Using Chalkdusts pc as mine is again, playin up ( a bit like my car :rolleyes: )
  5. ashdb1
    ashdb1
    you know you said the time delay doubles.... will i have to leave it say 32 mins in one go or can i turn it off and it carrys on ? please get back to me thank you
  6. Ayub
    Ayub
    Oct 15, 2003
    6,657
    Bradford
    +612
    Go on a long journey leave the stereo on and let it reset it self. If you take it to a shop they will do the same.
