Renaming AirTunes "My Computer" Label
Discussion in 'Music Streamers' started by fatnoo, Mar 26, 2010.
  1. fatnoo
    fatnoo
    Mar 9, 2010
    10
    Hi all,
    Does anyone know of a way to change the label for "My Computer" in the speaker list when using AirTunes?
    I presumed it was picking up the label from my actual computer name (set in properties of My Computer), but alas no.
    Any ideas?
    Many thanks.
  2. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    iTunes > Edit > Preferences > General Tab
    There you can change the library name.
  3. fatnoo
    fatnoo
    Mar 9, 2010
    10
    Hi Trailer,
    Thanks for your reply, however the library name
    change does not seem to change the 'Computer' label.
  4. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    It uses this name when I use the remote app on an iTouch / iPhone.
    How are you using AirTunes?
  5. fatnoo
    fatnoo
    Mar 9, 2010
    10
    With Remote on my iPhone.
    When Remote connects it says "Connecting to Library Living Room", but the speaker choices are "My Computer" and "Conservatory" (the AX).
    Renamed library and rebooted everything, but still labelled as "My Computer" in Remote and iTunes itself.
  6. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    Ah OK, got you now.
    I'm not sure if there is a way to rename that to be honest unless someone else knows?
  7. timeshifting
    timeshifting
    Jun 8, 2010
    3
    It can be changed in these files, for US and GB English:
    "C:\Program Files\iTunes\iTunes.Resources\en.lproj\Localizable.strings"
    or
    "C:\Program Files\iTunes\iTunes.Resources\en_GB.lproj\Localizable.strings"
    Find and edit these lines:
    "163.034" = "Computer";
    "163.035" = "My Computer";
    163.034 is shown in the iTunes UI drop down list
    163.035 is shown in the speaker list in Remote.app on iPhone OS
