Removing XP
Discussion in 'Desktop & Laptop Computers Forum' started by richjthorpe, Mar 13, 2006.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    When I built my PC I installed XP Pro on the D: drive instead of the C: drive, so I installed it again on the C:. How do I remove the version on the D: drive ?
    Richie.
  2. TiSwAs
    TiSwAs
    May 2, 2005
    387
    Blackpool
    +20
    Just format the D partition/drive through XP that u r using now...
    But if you want to keep other files that aren't store in the installation directory on D:\ just delete the directory D:\Windows.
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Already started ripping a few Gigs worth of music onto the D: drive although a format would have been on the cards ! Although I might be able to move it across to the C: drive while I format it...... hmmmmm.
    Would deleting the the Windows directory be enough ? What about reg settings or will they be used by the C: version of XP ?
  4. dynamitetony
    dynamitetony
    Aug 23, 2005
    225
    +10
    if you have installed windows on to your new c: and are using that, then the version on your d: can just be deleted, it shouldnt effect anything to do with your registry
  5. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    You'll probably want to get rid of a few more folders on d: too, assuming you've not got anything important stored away in your (old) my documents folder etc.:
    "d:\documents and settings"
    "d:\program files"
