removing the stand from a Toshiba 32WLT68?
Discussion in 'LCD & LED LCD TVs Forum' started by markovts, Apr 27, 2007.
Tags:
  1. markovts
    markovts
    Feb 15, 2006
    28
    anyone know how to remove the stand from the main body of the tv? i wall mounted mine the other night but i've had a nightmare of a time trying to get the stand off.
    there's a HUGE nut on the underside, so have eventually managed to loosen this and remove it after blood sweat and plenty of tears. but even with this off, i still can't remove the stand section.
    there's nothing in the manual on how to remove it, even on their website.
    anyone got any ideas? :lease:
  2. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    Is it meant to be removed? Does the TV come with a panel to place in the TV if you take the stand out?
    I have had 2 samsungs and both came with plastic panels to cover the hole left by the stand when its removed.
  3. marlowdrummer
    marlowdrummer
    Feb 6, 2006
    157
    +72
    Erm, that sound very wrong. There were 5 allen bolts at the back of my 37WLT58, they came out and the TV lifted straight up. Sounds like you are taking the stand apart rather than off.........
    The bolts are usually in a box pattern with one in the middle.
    HTH.
    marlowdrummer
  4. rickoshea
    rickoshea
    Jul 11, 2005
    99
    Sussex by the Sea
    +4
    I am trying to remove my stand and having the same nightmare. Did you ever work out how it's done??
