Removing the screw cover on ESPAG window handle
DarkDogZA
Hi All
The window lock on my kitchen windows has broken (the spring has gone). I managed to get the handle to move by using a tool to press the lock handle. I can now remove one of the screws on the window latch.
The issue is the other screw. It is situated under a screw cover that is being an absolute beast to get out. Anyone have any tips for me please?
Thank you.
larkone
If the cover is plastic try warming it with a hair dryer, if it is metal try a bit of WD40 around it
DarkDogZA
cheers! That worked
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
