Removing the ****** banana plug protector plastic caps on a Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by dave48, May 18, 2002.
Tags:
  1. dave48
    dave48
    Mar 9, 2002
    279
    Germany
    +6
    Can someone please tell me *exactly* how to remove the plastic caps on the speaker connections on a Denon 3802? All I want to do is connect my cables via banana plugs, rather than having to shoehorn a bit of frayed wire into the hole and tighten the plastic wotsits.
    I'd like to do this without damaging the screwable plastic red / black wotsits if possible!
    I've tried poking around with a small screwdriver with the wotsit tightly screwed in and also screwed out to the maximum - but no success yet.
    These plastic caps are a real pain - though I suppose maybe someone sometime did think it was a mains socket .... But that's what natural selection is there for, isn't it?
    Cheers for any help,
    Dave48
  2. martian1
    martian1
    Dec 30, 2001
    2,465
    113
    Sunderland
    +678
    very thin screwdriver best [i have a set, watchmaker type] dont fanny about being to gentle or they wont budge, push in side firmly then give a sharp flick! youll have the buggers firing across the floor in no time.
  3. bob007
    bob007
    Tried that, got a slap round the face from the missus.....;)
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Have I wandered into the gay forum by mistake ?
  5. dave48
    dave48
    Mar 9, 2002
    279
    Germany
    +6
    Thanks - that sorted that problem out. Now I just need to sort my watchmakers screwdriver out - it is not quite as straight as it used to be ....
    Dave48
  6. martian1
    martian1
    Dec 30, 2001
    2,465
    113
    Sunderland
    +678
    What! youve ended up with a bender. Well you will visit these dodgey sites...:eek:
  7. Jules
    Jules
    Oct 11, 2000
    5,633
    134
    +1,121
    I used a pair of thin 'long-nose' pliers.
    It was peasy!. Just gently insert one of the 'noses' into the hole and then pull it out. The teeth on pliers grip it on the way in, so it has to come out when you remove the pliers.
  8. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    HI
    Now that this yam has been sorted how about the 3090 its a pig to squeeze thick wires in
    the screw in ends dont screw off very hard plastic ends i have tried the **** them method with no luck do they remove to take bannanas or is this yam to slipperly
    [email protected]
  9. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    This is a technical method that I haven't come across before.
