Removing sub grill
willz
Hi, i have took the screws out of the Z5500 subwoofer, yet the grill still wont come off, is there any way to take the front grill off? would pushing somthing thin inbetween the gap and then pushing the grill do any good?
Knyght_byte
is there any particular reason you actually want to remove the grill or is it just aesthetics?..heh
you may find that the grill extends in to the surround cabinet and isnt really removable....
quite likely the faceplate around the sides of the grill is glued on using industrial stuff....so it may not be advisable....
other option is to get a pair of very thin long cutting pliers....and cut the grill out..lol..but be very careful not to stab the bass driver...heh
willz
Yea i just want to remove it because i like to watch the sub when its at full swing. :p
Awwww noo, so its not really removable ? :( i dont want to cut the grill out, and i am sure other people have managed to remove the whole grill thing withought cutting the metal out, check the videos in the videos section/logitech on realm of excursion, i am sure some of the z5500 subs there have the grilld tottaly removed and not cut.
I dont think the actual metal grill bit extends into it because if you look down the small gap you can see, its just were the screws are by looks of it i think.
Someone said to use a hairdryer to remove the grill once, that did not work :(
Knyght_byte
hairdryer????
the mind boggles
well, try and force something, but i didnt tell you that, its at your own risk if it buggers it up.....lol
willz
Lol, i will try to force it, but of course i dont want to break anything, especially the driver.
Damien_Ireland
Knyght_byte said:
hairdryer????
the mind boggles
Hair dryer would be good if it was glued to the box as the heat off the dryer will heat up the glue and make it easier for the grill to come off.
willz
If only someone that likes to take risks would do it :p
Knyght_byte
it would also help melt the rubber surround of the bass driver....LOL
willz
Loooolll i dont think its rubber, looks more like foam lol, yea its foam, thats logitech for ya :\
willz
I dont think a Hair Dryer would melt rubber anyway, its not that hot!
Similar threads
