Removing "Recently Added" in iTunes
Discussion in 'iPhone Forum' started by Mr Forgetful, Apr 24, 2007.
Tags:
  1. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    Could anyone be so kind and tell me how I remove the music in the "Recently Added" folder without removing the music completly from itunes?
    The reason I ask is because I wish to copy several CD's into iTunes and then transfer them to my iPod from that folder but I have hundreds of music in "Recently Added" already and don't wish to copy the remaining music twice.
    Dave
  2. wicker_man
    wicker_man
    Apr 22, 2007
    1,298
    Brighton
    +116
    Songs aren't added more than once on iPods, it just shows in whatever playlists it appears in.
    If you want, you can delete the 'recently added' playlist from the sidebar by just pressing delete on your keyboard. Your songs shouldn't be deleted.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    Removing items from playlists, or deleting the playlists themselves, does not remove the items from the iTunes Library or the iPod. Playlists are just pointers to the original music files.
  4. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    Thank you for your reply, is there a way of deleting the music from the "Recently Added" playlist without those songs being deleted from the main "Music" folder?
  5. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    I thought that is what should happen but when I deleted the music in the the "Recently Added" playlist/folder, the music also deleted entirely from iTunes and I have needed to copy all from the CD's again. I tried it twice and it came up with the message "Are you sure you want to remove the selected songs from your iTunes Library"
  6. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    Click 'No' and it should delete it from the Playlist, but not from the library/PC
  7. Chox1988
    Chox1988
    Mar 30, 2005
    16,795
    basingstoke
    +9,162
    Are you deleting the playlist or the songs individually within the playlist?
  8. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    I wish to delete the songs from the playlist, not the playlist itself.
    If the songs are deleted from the "Recently Added" playlist it removes the song entirely from iTunes/PC
    The options that come up are "Remove" or "Cancel"
  9. Chox1988
    Chox1988
    Mar 30, 2005
    16,795
    basingstoke
    +9,162
    Is it a smart playlist or regular playlist?, if you set up a smart playlist you can set it so it only shows you certain songs so it updates itself
  10. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    Yes, it's a smary playlist that's time based, shortening the time span may well do the trick.
    Alternatively, remember the albums you've ripped and simply transfer those!
  11. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    Excellent, thank you, I've been into edit smart list, this will help considerably.
    I still think it's a tad strange that if you delete the music from the 'recently added' smart list it removes totally from iTunes and from the PC
    Once again, thank you:thumbsup:
  12. RB05
    RB05
    It doesnt
